跳转到主内容
Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
Very high leak rate on report screen
I get very high leak rates 40 to 70 L/min indicated with no mask seal alert and no warnings. Mask,tank,and tube all check good with no leaks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
i have same problem i fix it by replacing the mask and program the cpap with the new mask .. it works.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue. I’m replacing the first internal gasket before I try the harder to replace air pump gasket. https://www.directhomemedical.com/resmed...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Kracke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 730
