跳转到主内容
加入维修社区 - 创建账户
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
Laptop doesn't charging of T2 broken chip?
faced an interesting situation: the laptop got water, the laptop is working but has stopped charging. the master replaced the power controllers, but the laptop does not charge. After charging battery on another laptop - the laptop works.
Here’s the question: the master says that the problem is in the t2 chip, although as far as I know, the t2 chip does not in any way manage the battery power, but the SMC chip is engaged in this ... can you enlighten?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Who is this Master person??
完成的
well ... let's keep his name incognito ))))
完成的
添加一条评论
1个答案
Your system has two power controller chips one per port (orange marked chips) and the Power manager chip (Green chip) and you still have the Thunderbolt controller chips (Purple)
So its possible the other chip is also bad, and as this was liquid damaged its possible the port assembly is damaged as well.
The T2 chip doesn’t get involved with SMC basics thats why you have a micro controller to deal with this level of housecleaning (Yellow chip).
Basically without having direct access to the system and inspecting things its just a guess on what’s wrong.
Maybe you need to bring your system back to the Master to fix it properly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Software Architect IoT 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 199
