跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether self-propelled or “walk-behind.”
Mower won't start just clicks
I have a 24 hp killer engine. Have replaced starter, solenoid ,checked battery still won't start just clicks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I'm just guessing you meant to say "Kohler" engine. Possibly with a few more details (e.g. engine model #, equipment model #), someone could help you.
完成的
添加一条评论
1个答案
Hmmmm, where to start?
Make sure your battery is well charged.
If that doesn't do it, suspect a bad starter solenoid.
To test a starter solenoid, connect a test light to its output terminal then see if it has current. If the light comes on, that tells you this IS power going to the solenoid. If the light does NOT come on, check your battery!
Once you know you definitely have power, see if that power is being transferred properly by switching the red lead to the solenoid’s lower terminal.
Here is a video. Hope that helps!
https://www.youtube.com/watch?v=MsvJMnpQ...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
millard knight 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 271
