跳转到主内容
Repair information for standalone freezers.
192 个问题 查看全部
Replacing thermostat on chess freezer
So, I am proceeding to replace the thermostat on my Danby Freezer Model DCF401W. However the new thermostat has a longer probe (about 7inch longer) than the original. I am unable to push it further. Can I leave the extra inches out? Should I cut the probe and seal it back? Suggestion?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sears Parts indicates the part is no longer mfg by Danby and there is no substitute part available.
Since you have something you can choose to return it or butcher it up to try to make it work.
If you succeed, a feather in your cap. If you do not, to the dump you go.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sebastien G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 32
