跳转到主内容
White screen all the time even with computer off
Hello i ask for help here bc I'm pretty scared and have no idea of what to do
I jusr went out for like 45 minutes, my pc still on and everything was fine
When i came back my screen was entirely white, i tried turning off/on my pc but nothing changed, even with my computer off the screen stays white, unplugged everything except the power cable and nothing still completely white so i assume it doesnt have to be a pc problem but abt the screen
I have an acer predator 240hz (idk the exact reference) and it never happened before, I'm genuinely scared cuz that screen was expansive asf and i dont have the guarantee anymore
Please if someone can help me abt that I've searched on internet but i only find computer problems/solutions when im sure its only abt the screen
Thank you for your help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Update :
I opened my screen like in the video @salmonjapan sent me and i couldn't access the cables of the primary board bc it's glued or smth, i took off the screws and all but still impossible to move it a bit (it's not the exact same model as in video so maybe its different abt that)
So yeah my screen is still full white without me being able to do anything so if there's other solutions i could try pls tell me
Thank you for the help
完成的
@genior What is the exact model number? Look for label on back of monitor. This will halp us help you.
完成的
It's an acer predator xb272 bmiprz
If it can help
完成的
Also just to make things clear the problem come from the monitor bc I'm currently using a hold screen that works perfectly fine waiting for a solution
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @genior
Try removing the display cables and see if it helps.
Unplugging everything and pressing and holding the power button for 30 secs.
It seems you are not alone on this issues.
If you have warranty still, contact for service.
Else you might want to try on link below:
https://www.youtube.com/watch?v=qKLxzILd...
这个答案有帮助吗?
得分 1
1条评论:
Hello
I already tried removing all the display and turning it on with just the power cable and it stays white
I tried to hold the power button for 30 seconds just now but it didn't change anything either
I don't have guarantee anymore so ig I'll try the solution u sent me from ytb but I'm a bit scared to do bad things and just make it worst tho but if its the only solution I'll give it a try
Thanks for ur help
完成的
添加一条评论
添加你的答案
Genior jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 2,398
