跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
93 个问题 查看全部
Can I replace a 2015 retina display with a non-retina 21.5" display
Can I replace the 2015 iMac retina display with a lower resolution 21.5 2015 iMac display?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sadly just like replacing tires you need to stick with the correct size!
As you can see here the display data cable is larger as it needs to carry more lines of data! The box is the exact same size between the two images.
So no you can’t swap it out.
这个答案有帮助吗?
得分 1
1条评论:
A rookie question, but now I know. Thank you so much for that and the illustrated differences!
完成的
添加一条评论
添加你的答案
Roger Clay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 74
