Phone keeps turning off after motherboard replacement
I’ve replaced my s6 edge motherboard, everything went well when I switch on my device to test it but it just kept turning off I don’t know why if someone know how to solve this issue please help me.
Where did you source the motherboard? What was wrong with the phone that caused you to replace the motherboard?
由 teardown-er 完成的
It's possible that the power button cable became partially dislodged when you were replacing the motherboard. Try turning the phone on, selecting a setting that keeps the phone from turning itself off after a certain time, and leave the phone on without touching it for 30 or so minutes. Then see if the phone is still on. If it has turned off, the power button is probably not the issue.
由 teardown-er 完成的
@teardowns101I bought it from my Local repair shop, my s6 edge is from sk telecom carrier.
由 Itadori Yuji 完成的
