Samsung Galaxy S9 motherboard swap
I have purchased a fully working Samsung Galaxy S9 and will be swapping the motherboard from the old phone to new phone. ( will be cleaning the original motherboard from water damaged phone using some 99.9 isopropyl alcohol prior to swap and hope for the best, I believe the motherboard is OK and just the screen on the original phone was damaged.)
What I need to know now is on the new phone prior to swap, do i need to go through setting up the new phone prior to motherboard swap or do I swap before doing phone setup or does it not make any difference either way?
Thanks
Thanks everyone. the motherboard swap worked.
So a Galaxy S9 motherboard survived a full wash cycle in a washing machine just damage to touch screen only.
Purchased a mint condition S9 off ebay for £134 and having cleaned the original motherboard from water damaged S9 with 99.9% Isopropyl alcohol and swapped it over to new replacement phone and powered up the phone everything works!!!
Thanks for all the advice.
由 diezeltruck 完成的
Good job! Happy it worked
由 Innovatrix Repairs 完成的
