跳转到主内容
加入维修社区 - 创建账户
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
Problem with MagSafe2 Power Adapter after replacing the cable
Hello
I replaced the cable - MagSafe 2 (the old one was cut). After that i have a problem with charging. I have to plug the cable into the socket on the computer several times until it starts working. When I do that I can disconnect and reconnect and its ok but.. when I unplug the cord from the wall socket it not working again (charger reset?) ..
I have already try with 3 new cables (original) and problem is the same. When I use my old one its fine..
Do you have any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sadly it’s time to just get a new charger. I’ve never been a fan in patching the cable together as the connector has a tiny chip inside which tells the system what the charger is.
Why this is important is the voltage and needed charge rate is not the same across all of the chargers. So the cord you snagged may be for a different charger! Here’s more on this Teardown and exploration of Apple's Magsafe connector
So what to get?? Don’t waste your money on the knockoff chargers they are just not safe! Lacking safety features, cheap MacBook chargers create big sparks which can harm your system as well as set fire as my ex-employer found out having to fork over 4 million for one of their employee setting a hotel ablaze!
So get a REAL Apple unit directly from Apple as the sellers who claim its a real unit (or state OEM) are not selling you a real Apple unit. Fake Apple MacBook MagSafe2 charger, how to tell a fake, eBay scam
Here’s the chargers directly from Apple’s web site
这个答案有帮助吗?
得分 2
1条评论:
Thank you for respone. I will do that what you say :)
完成的
添加一条评论
添加你的答案
Konrad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 35
总计 703
