跳转到主内容
The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
71 个问题 查看全部
Is there anyway to reapair this gameboy?
I found my dad’s old Gameboy.
He told me that he left it with a cartridge and batteries, around 20 years ago. I decided to check if it would work, but I saw the corrosion and decided to check inside. Well it looks like this
Didn´t look good. But then I saw the other side.
I’m pretty much sure that this thing is cooked, and the only way to work is to get a new motherboard. But I still wanted to get a second opinion. Is there any way to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hard to say but it is worth trying. Remove the logic board and brush with Isopropyl alcohol. This should remove all the corrosion on the top layers. If you did not attempt to power it on and the corrosion hasn’t corroded the traces on the other layers of the logic board there will be a good chance it might work.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
roroanama 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 78
