跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Why target displaying mode not working?
Try to use my 2009 iMac 27” desktop as an external monitor, but can’t get the target displaying mode working, when connecting with the MacBook Pro 15” through mini-display port cable, the screen just flash into black, then back to itself again, samething when pressing command and F2. Any ideas why the target displaying mode not functioning?
Thanks,
Alex
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Review these:
Make sure you are using the proper cable as some configurations won’t work if you use the wrong cable (iDP vs TB as well as the generation of TB)
这个答案有帮助吗?
得分 1
12条评论:
Thanks Dan, by reviewing those two articles you referred, it seemed that the Mac OS on iMac needs to be high Sierra or earlier, the current one installed on mine is Catalina, is this the reason why TD feature won’t work?
完成的
@hru1207 - I haven't used it in years so I can't say if Mojave or Catalina still supports it.
完成的
@danj - By googling around, it seemed that OS version is the key, so, I will install Hi Sierra and see how it goes. By the way, another question I have is that I upgraded the SSD into this old iMac, the way I did is to replace the optical drive with the SSD adaptor and put the 2.5" sata SSD there, it works fine. However, I heard that doing this way may not have the same performance as to use the original hard drive slot. Is that true? Thanks in advance!
完成的
@hru1207 - You'll need to clue me in here which system your iMac or your MacBook Pro and which model of MacBook Pro (size and year)
完成的
@danj - Sorry for the confusion. The iMac is 2009 27” model with I5 cpu, and trying to install the SSD now, it seemed to me that it will be much easier just replace the optical dvd drive with the SSD adaptor, instead of replacing the original hard drive from its slot, but not sure if the performance will be the same at these two methods, any thoughts?
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 187
