跳转到主内容
Released March 2019, identified by model number SM-A305FZRFINS
My phone will randomly lock my screen and rapidly
For the last few days out of no where my phone ( Galaxy A30) will lock and unlock itself as if the power button has been pressed, and will act as if the button keeps getting clicked, the screen will start flashing rapidly when it does this, the power button doesn't feel stuck or anything, so my first thoughts is that the problem is a software issue, I've turned it on is safe mode, wiped cache partition, and finally I've done a factory reset, I can't find any other problems quite like this. I have tried keeping the device turned off for a while and fully charging the phone, but it keeps doing the same thing, if anyone has any ideas what could help me resolve this, I would appreciate this, So I can know what to get fixed. Please. Thank You.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
Does the phone ever randomly try and turn on? The power button might be broken, but it might be a software or processor issue
完成的
Is your phone a Samsung Galaxy A50 or A30?
完成的
@teardowns101 I'm really hoping it's a powerbutton issue, cus a processor issue means the phone's done for right?
完成的
@Jerry Oti Yes, if the processor is having an issue it is almost certainly unfixable (unless you buy a used processor and board). However, it is much more likely that the power button was damaged and needs replacing
完成的
添加一条评论
1个答案
已选择的解决方案
I'm almost certain your issue is a shorting power button flex ribbon. You can get a new one here.
这个答案有帮助吗?
得分 2
2条评论:
I'll second that
完成的
Okay, I just ordered it, it's coming with the full Middle Frame/Bezzel. I hope it fixes it thanks @andrewawesome
完成的
添加一条评论
添加你的答案
Jerry Oti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 5,261
