跳转到主内容
Repair guides, service information, and troubleshooting help for Electrolux Refrigerators.
Frigidaire refrigerator not cooling enough (Condenser coil is cold!)
Hi, I have an 8-year old Electrolux Frigidaire top freezer refrigerator, Model: NFTR18X4LWA.
Recently, both the freezer and the fridge are not cold enough. There is cold air blowing in both compartments, but freezer only gets to around 32F degree. Door sealing is fine.
I cleaned the dirt around condenser coil and compressor/fan at the back bottom, did not help.
Compressor lightly hot (ok to touch by hand), compressor fan is running, but condenser coil is cool: I feel that's the problem. The pipe connecting the compressor and condenser coil is hot close to the compressor side, but then quickly cools down before it gets to the 1st loop of condenser coil. The pipe (going into the freezer) besides the compressor is cold but not frozen.
Will I have to replace the compressor and/or condenser coil?
Can I assume the evaporator coil/fan etc in the freezer are good? We can feel cold air blowing (just not getting below 30F degree). Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Thank you @brandon_k and @jayeff for the great suggestions!
We finally determined that the freezer and refrigerator temperatures won’t drop to low enough degrees even if we force the compressor to keep running for a couple of days continuously. The freezer will just stay ~32F degrees. Both the evaporator fan and the fan between the compressor and the condenser coil run fine. We believe the compressor/sealing system got some issue and it’s not worthwhile to repair the parts. So we just purchased a new 18 cube ft fridge.
Very good learnings through your guidance any way and we appreciate the great help!
完成的
@coolerst Hey not a problem. I don't blame you. If you aren't trained to work on sealed refrigerant systems it is very easy to do something very wrong. Repairs can add up too, if you have to call someone out!
完成的
添加一条评论
2个答案
已选择的解决方案
Hi @coolerst ,
Usually the condenser fan only runs when the condenser coils are too hot. It is thermostatically controlled and only runs when necessary.
Is the compressor running continually trying to drive the temps down or does it stop occasionally as if it thinks that the set temps have been reached and then starts up again a short while later?
If it does stop when the set temp has not been reached, it may be a temp control thermostat problem, part #21 shelves diagram
Can you hear the evaporator fan running in the freezer compartment?
It will stop if a door is opened and start again when the door is shut. It should be running as long as the compressor is running.
Are the evaporator coils icy cold to the touch?
Here’s the wiring diagram which may help as it also shows the sealed system high and low pressures. If the evaporator is not getting cold then there may be a problem with the compressor, a blockage in the sealed system or a lack of refrigerant due to a leak.
Depending on your location you may need a licensed repairer to check the high/low pressures in the sealed system due to the environmental regulations regarding the handling of refrigerant gases. Testing the pressures will help to determine what and where the problem is.
这个答案有帮助吗?
得分 2
6条评论:
Hi @jayeff, Thanks for the quick reply with many details!
The tenant said "it stops occasionally". So that could be temp control thermostat problem.
I haven't open anything in the freezer yet. But I did hear the evaporator fan running, and my finger could feel the cold air blowing. It can also bring temp down to around 32F degree (from a thermometer put in the freezer). I think the evaporator fan was still running when I opened the freezer and put my finger close to the vent.
I will try open up and check evaporator coil's feeling next.
I still don't understand why that condenser stay cool when compressor was running and hot (good to touch by hand for a long time). I compared to my home fridge (good) and the good compressor feels hotter (may touch by hand but not for a long time) than the bad one.
Thank you!
完成的
@coolerst
Check if the freezer light and refrigerator light turn off when you manually operate each of the door switches withthe door open.
Usually the evap fan turns off when a door is opened as you don't want to blow any cold air out.
The way it does this is usually through the door switch i.e. door open light on fan off, door closed , light off fan on. This is of course as long as the compressor is running as well.
The condenser coils should feel warm as this is where the heat from the compartments, which is absorbed by the refrigerant in the evaporator unit, is released to the outside air, before the refrigerant then passes through the expansion valve which changes it to a gas again and it passes through the evaporator i.e. now refrigerant is literally freezing cold.
If the evaporator is not freezing cold - be careful not to get your fingers literally stuck to it - then there is a problem with the sealed system, compressor, evap unit, condenser, piping or refrigerant. The only way to know is to find out the pressures.
Sometimes a leak may be indicated if there is an oily residue on the condenser or the compressor. There is a special oil mixed in with the refrigerant to lubricate the compressor and if there is a leak then the refrigerant will escape undetected but the oil may leave a trace, but not always and not if the leak is where you can't see it.
完成的
Hi @jayeff ,
There is no freezer light. The refrigerator light does turn off when I manually push down the door switch.
I opened the back panel board in the freezer: the evaporator coil has a little ice and quite some frost (feels like snow). I can't really tell if the temperature on the evaporator coil is freezing cold or not (should be below 32F degree but not sure if may reach 20F or lower). The evaporator fan runs fine.
The ground/back does not show any leak of refrigerant.
完成的
Hi @jayeff
I tried to rule out temp control thermostat problem by bypassing it, directly shorting the 2 pins connected to temp control thermostat's output (just to see whether temperature may drop to low enough if running compressor for long enough time). But after the short, the compressor still stopped after ~40 min. Then waited another 10 min it did not restart again. I plugged out power cable and plugged in did not start compressor either. I checked the short of the 2 pins connected to temp control thermostat's output and they were fine. I removed the short and connected the 2 pins back to connected to temp control thermostat's output -> the compressor still did not run -> I thought I must have broken something, but then after 1 couple minutes, the compressor ran again!
So what's the proper way to force compressor always running? Looks like shorting temp control thermostat's 2 output pins is not enough. Does the small timer box (close to the temp control thermostat) need to be hacked as well? Thanks
完成的
Hi @coolerst
OK.
The temp control thermostat goes via the defrost timer, part #23 -shelves diagram.
This timer controls the duration of the defrost cycle. The defrost cycle usually occurs once every 8-10 hours and lasts for about 20-25 minutes.
During this time the compressor is turned off and the defrost heater under the evap unit is turned on to help melt the accumulated ice from the evap unit.
The evap unit is protected from being damaged by a bi-metal thermostat which operates at about 50°F (it is close to the heater and measures its temp rather than the ambient in the compartment) to cut off the heater. Once the defrost timer ends its time for the defrost cycle the compressor is restarted to drive the temps back down again. When the temp in the freezer reaches about 25°F the bi-metal thermostat releases, enabling the heater circuit to be ready for the next defrost cycle 8- 10 hours later.
The point of all this is to tell you how it works and that the problem may be a faulty contact in the defrost timer.
If you check the "wiring diagram" i linked in my answer, the Refrigerator Compartment section applicable to your model (as there are two shown - lower left side of diagram) is the one on the right of the two with the timer and not the one on the left with the ADC board.
This may help to show you how the temperature thermostat connects through the timer to get to the compressor, so it is either the thermostat that turns off the compressor when the set temp is reached and turns it on again when the temperature has to be colder due to doors being opened and cold lost etc OR the defrost timer turns it off to commence the defrost cycle and turns it on again at the end of the timed defrost cycle. It is no use running the compressor trying to cool things down when you are trying to defrost.
With most auto defrost refrigerators you will notice that the freezer temp is about 0°F when set temp is reached and during the defrost cycle it will go up to about 32°F to help melt the ice with the heater and then when the defrost cycle is over it goes back down to 0°F again. Usually it never gets above this as you don't want to start defrosting the food.
完成的
显示更多的1条评论
添加一条评论
I hate to be the bearer or bad news, but from the symptoms you've described… it sounds like you've most likely lost most of your refrigerant. Or, there is a failure internally on that hermetically sealed compressor. Now here's why I say this… your compressor is running but isn't getting very hot, and the hot gas line from the compressor to the condenser coil starts warm near the compressor and then cools before hitting the condenser. Right? Alot of the heat generated inside a refrigerant system compressor is from compression. Pulling low pressure vapor from the suction side, compressing it into a hi pressure vapor into the hot gas line. That is then cooled by the condenser coil and fan into a hi pressure liquid, which is sent to the metering device (in something like this, I expect it to be a capillary tube.. very small diameter tube of a very specific length decided by engineers). That turns it from hi pressure liquid to low pressure liquid, and when that enters the evap coil, it boils off into low pressure vapor, absorbing heat. And it starts again. I'm likely to think refrigerant loss is the culprit, as you ARE getting some cooling. Which tells me that some refrigerant is being moved, which rules out an outright compressor failure. Though there could be issues with the internal valves, allowing blowback. Though that is VERY uncommon in my experience. So im thinking most likely it is refrigerant loss causing this. What is the temp of the suction line going into the compressor? Is it cool? Or warm like the other side? If it is warm as well I would think compressor might actually need replacing. You've already confirmed that fans are working, and coils are cleaned. The symptoms you describe tell me the problem isn't the defrost system, as if it were running when it shouldn’t, your compressor and condenser would be VERY hot, or if defrost termination didn't happen, compressor wouldn't run at all. So this means you need to check refrigerant levels (or, if not properly trained to, get a technician to do.it for you. Without throwing gauges on it at this point its very hard to narrow down further. Need to see suction and liquid pressures to check compressor operation reliably. Also, did you see any traces of oil? This would help narrow the leak. I can't say evap or condenser coil are good without leak checking them.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
cooler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 113
总计 9,075
