Phone issues after replacing battery with ifixit battery
So I replaced a galaxy s9+ battery with an ifixit battery. It worked beautifully for 24 hours. Then it suddenly started glitching. The screen would only intermittently turn on but when it was on there were no issues using the phone. Then the screen started flickering and turing green with lines through it. Some times the screen would turn black and I can feel the phone recognising finger inputs. Sometimes the phone will boot normally with no issue. But after a while it’ll start lagging and the screen will turn green or black. Anyone have any idea what is happening?
3条评论
But why would the screen work fine for a day? Maybe ill try and see if the cable is ok. Thanks!
由 vincent tsui 完成的
There is a liquid on an LCD panel, and something similar with an OLED panel. If there is a very very small crack in the panel, it can take a.while before the liquid gets out of the panel creating a delayed reaction from when the panel is damaged to when the side effects shows up.
I doubt it would be the cable concidering how far it is from the battery connector, but it does not hurt to check.
Do you have a repair shop near by? If you are confortable opening the phone yourself, you could ask them if they have a spare screen you could connect just for 1 min to see if it fixes the problem.
If the problem persist with a known good screen, then there is likely a component the got knocked off the motherboard during the battery replacement, but it sound more like a screen issue to me.
I hope this helps.
由 Innovatrix Repairs 完成的
Ok so I worked it out. The temperature sensor wasn't seated properly. It was causing the screen to initially work then green out after. Screen works completely fine!
由 vincent tsui 完成的
