跳转到主内容
佳能各种胶片单反相机的维修指南和支持,包括 EOS 胶片系列和佳能 Rebel 等便携相机。
76 个问题 查看全部
Button does not work.
I have a Canon SX50 HS. The circular dial just above the Menu button is designed to be turned (revolved),… or pressed in one of the cardinal points (North, South, East or West). Mine will not ‘click’ when pressed down on the East side. Is there anything I can do?
Update (08/19/2021)
I have tried the distilled water and Q tip that you suggested. Unfortunately it still doesnt work! Any other suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Get some distilled water (you don’t want tap or spring that could make things worse!) Slightly dampen a cotton swab (Q-Tip) now carefully wipe around the edge of the dial and button areas where you see a gap see if that helps..
Update (08/19/2021)
@tedwynne - Sadly its starting to look like the switch contacts are not working properly. At this point you'll need a new upper case assembly
It’s a bit of work to replace it. I strongly recommend you let a camera repair person replace the part.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Edward Frank Wynne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 26
