跳转到主内容
加入维修社区 - 创建账户
The Lenovo Yoga 920-13IKB is a two-in-one laptop that functions as both a laptop and tablet by flipping the screen around.
default boot device missing or boot failed
Thanks. I tried the restart you mentioned with the side button and disconnected the main battery. Many times. It does not work. I googled and it seems disconnecting the cmos battery for a few minutes helps. That is why I wanted to try this.
How do I fix the error “default boot device missing or boot failed”?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi,
Try getting into BIOS and check if the HDD is being detected.
完成的
添加一条评论
1个答案
This happened to me a bunch after I first got mine. I eventually sent it in to get it fixed, but for a long time I would just... wack my laptop against my knee, or otherwise hit it, until whatever was on the inside (the SSD, I suspect) wiggled back to where it needed to go. So long as I didn't bounce my laptop while it was on, it never bluescreened. Only after being transported in my backpack would that internal component get knocked loose again, only for me to beat the everliving crap out of it until it stuck back into its slot.
I think opening things up and taking a look at the SSD (even taking it out and putting it back in like we used to do with our GameBoys) would be worthwhile.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bonita 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 489
