跳转到主内容
Repair guides and support for Panasonic's Viera line of televisions.
417 个问题 查看全部
Panasonic Plasma TH-50PX77U: Sound but no picture:
I have a Panasonic Plasma TH-50PX77U TV with no picture but sound is perfect. Replaced circuit panel with HDMI ports last year and worked fine until recently. Menu selection options list is visible along with channel numbers. Can anyone help??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can you take off the back of the TV and look for any leaky or bulged capacitors?
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @irkman1 ,
Do you get a picture when using other input types e.g. component video or RF (coax)?
Here’s the no picture troubleshooting flowchart from the service manual which may be a good place to start.
If the problem is only on HDMI, the HDMI schematic is on p.43 and from there you can follow it through to the DSP (digital signalling processor) etc.
Just wondering if you had been “hot swapping” the HDMI cables to the TV by any chance? If so this is not a good practise as it can damage the HDMI controllers (at either end, source and/or host). They should only be unplugged/plugged in with the power turned off on both devices .
这个答案有帮助吗?
得分 1
添加一条评论
the previous answer assumes you have removed the back. Probably not. I had to replace 2 of the large caps in my panny 50PZ77U a couple years ago. TV still worked but they were definitely going bad.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Weiss 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 78
