跳转到主内容
Dell Streak was released on August 13, 2010 and is exclusively available on AT&T's cellular network in the US.
11 个问题 查看全部
Prying the LCD Screen sub assembly from the Gorilla Glass front panel
In STEP 14, it says : ""Sadly, the Streak's LCD is permanently adhered to the front panel glass. However, that LCD/glass subassembly is held in the front panel with very strong 3M adhesive, and could be removed with enough careful prying.
The LCD is bonded to the front panel glass to increase the strength of the device and sensitivity of the capacitive touch panel.
The inner face of the front panel assembly isn't all that exciting. The ear speaker and vibrator motor can be seen near its top edge. ""
Does anyone have pictures or video of this "prying" process and how can i make sure that the part i order will not need special adhesive to re-attached the "pried" part? thanks for your help, I will post pictures of my repair process of the screen once i am successful at tearing the Dell Streak down and replace the screen.
Wish me Luck !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Don't pry it!! You'll probably end up breaking it!
Instead, get a hot air hairdryer or a heat gun and heat up the area where the adhesive is for a while. Use something plastic to see if its loose, then once it is, it'll come off pretty easy.
I had to do the same thing when my Atrix's screen shattered.
Good Luck
-Luc
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
visioneye 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 974
