跳转到主内容
The Apple Extended Keyboard is a USB-A extended keyboard with an aluminum body and a numeric keypad.
Mac keyboard typing wrong letters
hi there!
I’ve got issue with my extended mac keyboard. As an exemple when i’m punching the letter P, the O also appear.
It also doing it with the L and the ;
I noticed that these keys are alongside on the keyboard.
Someone have a solution with this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You must have had a spill into the keyboard so the signal lines are damaged shorting out.
Think of it this way… Your keyboard is a grid of horizontal and vertical lines. The point where they cross is the Key shorting them to make the given signal to the keyboard encoder. This is all done within the keyboard.
Sadly, Apple does not design its newer keyboards as serviceable. Time for a new keyboard ;-{
这个答案有帮助吗?
得分 0
1条评论:
Thanks a lot for your answer Dan! :-)
完成的
添加一条评论
最有帮助的答案
Replacement required
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jean-François Duguay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 3,395
