跳转到主内容
Also known as the PS one, or the PSOne, this device is the slim version of the original PlayStation, released in 2000.
20 个问题 查看全部
My AV Port doesn’t work?
So I went to play on my PSOne the other day and found that plugging in the AV connector to the console and TV did absolutely nothing. It’s worked perfectly in the past but recently does not. I swapped for one that I know works and it still didn’t give anything different. My TV doesn’t recognise Ive plugged in the console. I tried a different TV too and nothing happened. Is there anything I can do to fix it that doesn’t require tediously going through with a multimeter and soldering on new bits?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Unfortunately, you may have to do some soldering. Can you open up your PSOne(guide here) and smell or whiff the circuit board? If so, does it smell fishy?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Justice Koester 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 203
