跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 个问题 查看全部
MacBook Air A1237 gets really hot
Whenever I do anything basic such as simply using arctic fox on Mac OS X 10.6 and searching the web my mac would get extremely hot and slow while the fan would be on full blast. I’ve repasted the cpu and I’m not sure if it has helped much, and I’ve looked though some sites to find a solution and I’ve found a software for undervolting the cpu called coolbook but i am unable to purchase it at this time. Is there any way to keep it cool?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Let's get some deeper details. Have your run the onboard diagnostics (depending on the running OS) or the CD/USB version?
Also let's install this gem of an app so we can see how your battery is doing CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片 Given your systems age its likely in need of a new battery and this could be the cause of the running how as the charging logic and SMC maybe running hard.
I would also look at your drive how full is it, maybe you should backup your stuff using TimeMachine, erase and reformat your drive and reinstall the OS, Lion (OS-X 10.7.x).
这个答案有帮助吗?
得分 0
2条评论:
I have not ran any diagnostics yet. I reinstalled mac os lion earlier and I have added the coconut battery image.
完成的
@syntaxf - You may need to trim down what you currently have on your drive or look at upgrading it as looking at the menu stats it looks quite full!
These older Air systems just don't have much RAM or storage which does make things harder. OS-X & MacOS will leverage the drive for Virtual RAM, but you need to have free space for that! Try to keep about 1/3 of the drive free to get the best performance.
完成的
添加一条评论
添加你的答案
Name 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 21
总计 94
