跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Reboot and freezes when using USB / Wifi
Hi. I got a second hand iMac. The machine boots OK, i could install systems (tried 10.11 and 10.13). The Mac works correctly (seems), as long as I don’t use a USB scanner or try to access the internet.
When I do, I get all sorts of weird things: black screen and reboot (also happens some time when just using software), grey screen (most often), blue screen (once), other screen colors - in any case it freezes and will only boot again after resetting the PRAM (several "sound + reboot” for about 20 seconds). Replacing RAM did not help.
I have to decide if I try some repair or break the machine into spare parts. I think it’s a board problem, but which board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Have you tried running the onboard diagnostics yet? Restart your system and press the D key
Reference: Mac startup key combinations Let us know how it goes
完成的
I did. Diagnostics don't show anything.
完成的
添加一条评论
1个答案
With no error its a bit of a hunt and peck ;-{
I would start off with the power supply and then you’ll need to look deeper into the logic board circuitry.
这个答案有帮助吗?
得分 0
3条评论:
OK. but what do I look with the power supply? How to test it? Actually, same question with the board. I mean if it does not show from outside...
完成的
@tcoulon - I would just replace it unless you have the skills to test it,
完成的
OK, I unmounted the screen. The board of the power supply is full of white marks, I guess it's a bad omen... The other boards "look" good.
完成的
添加一条评论
添加你的答案
Thierry de Coulon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 75
