跳转到主内容
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
124 个问题 查看全部
Does the force touch need to be replaced on the Apple Watch?
I was just wondering since Apple disabled force touch on all Apple watches, if during repair the force touch ring is damaged, does it need to be replaced and are they are consequences if it’s not replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hello Limar,
The Force Touch ring also functions as a seal on the model 4. The cost of the new one is $ 0,5 -1.5 in proper part shops.
Regards,
这个答案有帮助吗?
得分 1
2条评论:
Good question! I don't think anyone has tested to see if not putting it back will make a difference.
Frankly, I would put it back as the thickness will affect the crystal and displays position. Space is tight inside so the gap between the back of the display and the logic inside maybe too close which could damage things. The lack of load of the input could also mess things up.
完成的
Here's the needed part [[ 无效部分链接 ]]
完成的
添加一条评论
添加你的答案
Limar Zazai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 161
