Dryer turns off mid cycle with clothes BUT it runs fine when its empty
Our dryer will run fine when it’s empty. But when you put a full load in, it over heats and stops in about 5 minutes. If you try to dry half a load, it turns off around 10 minutes. If you only dry 1 or 2 things, it works. Is the motor bad, and any sort of weight will make it stop??
3条评论
Hi,
What is the make and model number of the dryer?
由 jayeff 完成的
Hi @jayeff ! Its a GE Dryer,
WLSR20000G3WW
由 Beth Sipzner 完成的
@jayeff OOPS this is the correct Model # DJXR433EG0WW
由 Beth Sipzner 完成的
