跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Sleep Wake failure in EFI after new battery installed
Ever since changing the battery in my MacBook, I’ve been getting this error every time I close my lid and the computer goes to sleep. It doesn’t wake back up when I open the lid, I have to press the power button and boot it up. I’ve tried resetting the SMC to no avail. I get this error:
Failure code:: 0xffffffff 0x0000001f
Please IGNORE the below stackshot
Date/Time: 2021-08-01 19:12:10 -0400
OS Version: ??? ??? (Build ???)
Architecture: x86_64
Report Version: 29
Data Source: Stackshots
Shared Cache: 0xc728000 867DFE32-D70B-31FB-9235-19DB52F41CA4
Event: Sleep Wake Failure
Duration: 0.00s
Steps: 1
Time Awake Since Boot: 10s
Process: swd [283]
Footprint: 400 KB
Start time: 2021-08-01 19:12:10 -0400
End time: 2021-08-01 19:12:10 -0400
Num samples: 1 (1)
Thread 0x76e 1 sample (1) priority 4 (base 4)
<thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 2>
1 start + 1 (libdyld.dylib + 109769) [0x7fff73a61cc9] 1
1 ??? [0x109863454] 1
1 ??? [0x1098631dd] 1
1 __stack_snapshot_with_config + 10 (libsystem_kernel.dylib + 135862) [0x7fff73bc32b6] 1
*1 ??? [0xffffff80002c3206] 1
*1 ??? [0xffffff8000983cd7] 1
*1 ??? [0xffffff800089c7f1] 1
*1 ??? [0xffffff80002e69e7] (running) 1
Binary Images:
0x7fff73a47000 - 0x7fff73a7dfff libdyld.dylib (750.7) <AB99C9EE-7127-3451-89AB-339F8F2CEE61> /usr/lib/system/libdyld.dylib
0x7fff73ba2000 - 0x7fff73bcefff libsystem_kernel.dylib (6153.141.35) <FDF91BB8-B353-3B7F-8644-3BA7AFBC2309> /usr/lib/system/libsystem_kernel.dylib
Model: MacBookPro9,2, BootROM 422.0.0.0.0, 2 processors, Dual-Core Intel Core i7, 2.9 GHz, 16 GB, SMC 2.2f44
Graphics: kHW_IntelHD4000Item, Intel HD Graphics 4000, spdisplays_builtin
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E4D3136464E00
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E4D3136464E00
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (7.21.190.33 AirPortDriverBrcm4360-1601.1)
Bluetooth: Version 7.0.6f8, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: Samsung SSD 860 EVO 2TB, 2 TB
Serial ATA Device: MATSHITADVD-R UJ-8A8
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB 3.0 Bus
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I'm *very* curious about how you arrived at this conclusion, e.g. that a "Sleep Wake failure in EFI" issue that began after replacing the battery is caused by a failing HD SATA cable. (I have a customer with exactly the same issue as described in the original post and am still searching for a solution.)
这个答案有帮助吗?
得分 1
2条评论:
@lorettodave - So did you replace the HD SATA cable yet?
Did you test the Hall sensor to see if the sensor is working properly?
完成的
@danj No, I haven't replaced or tested anything yet, as the MacBook is not currently in my possession. Once I get my hands on it, I'll try to re-seat the cable and potentially replace it (if re-seating and also resetting the SCM [again] doesn't help). I'll reply here when I have any updates.
完成的
添加一条评论
Sounds like the Hall sensor has failed. I would first make sure the HD SATA cable is plugged in fully. If that’s OK, I would just go-ahead and replace the cable as this cable is known to have problems! Your Hard Drive Cable Is A Ticking Time Bomb Make sure you don’t crease the cable as you also don’t want to damage it.
Here’s the needed part: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and the guide to put it in MacBook Pro 13" Unibody 中期2012 硬盘线缆替换
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable图片
产品
$34.99
这个答案有帮助吗?
得分 0
2条评论:
Hey Dan,
I replaced the hard drive cable and I’m still having the same issues. I went ahead and swapped the old battery back in to see if this solves the problem.
完成的
@gmtyree - Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
Beyond that I fear your logic board has a problem.
完成的
添加一条评论
添加你的答案
gmtyree 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 677
