跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 1420 14.1" laptop, released in June 2008. Identified as the 1420 on the bezel above the keyboard, available in 8 different colors.
some keys don't work on normal pressure
not too long ago some keys started misbehaving, they’ll work when pressed hard but not under normal pressure . Is there a way to fix this without changing the entire keyboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
From my experience there isn’t often much that can be done. You can try to pop off the keycaps and clean underneath them but you risk snapping the plastic mechanism and it may not solve the issue. Best bet is to replace the keyboard, for laptops of this age they typically aren’t too expensive and can be found pretty readily on sites like eBay and sometimes Amazon.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Felipe9999 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 213
