跳转到主内容
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
112 个问题 查看全部
Will I get a free replacement
I bought this MBP second hand with an issue, which IMO is a cooked T-CON Board.
It was bought in January of 2020, so the 1 year warranty is no more, but I am in Germany so we have a 2 year consumer protection law, this states: the seller has to warrant the product not having any manufacturing defects, but 6 months after the purchase it is the consumers duty to prove, that the defect was present at the purchase.
The MBP has never been opened, shouldn’t have liquid damage and doesn’t have any other issues I am aware of.
Can I “easily“ prove that due to the T-CON board sitting between the heatsinks, which apple only cools once the sensors reach “80+C“, it , in normal use, will overheat and get damaged?
Alternativly can I prove that I just never used it wrong?
Or can I get just the T-CON board replaced?
Simon
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The T-CON board is part of the display assembly and not replaceable on its own (not an available part).
As to prove the cause thats tricky! While we know and have seen lots of people hitting this issue, it would be hard to prove as either yours or Apples failure. Mostly I blame bad design as Intels CPU’s just run to hot from the limited cooling this system has.
I think you shouldn’t have any difficulty getting your system repaired.
这个答案有帮助吗?
得分 2
4条评论:
So I would have to replace my entire display assembly?
完成的
@simontt - Sadly yes, The newer design places the T-CON within the main case Vs the older design which had the T-CON within the lid assembly.
Note the difference in the cable routing between the case and the lid with two pathways in the older 2015 systems through the center of the hinges 2 small antenna coax cables and the camera's feed on one side and the other the displays backlight and video feed to the screen. Now with the 2016 onward systems we have four ribbon cables one for the camera, backlight and two for the raw video feeds all coming up the middle. The antennas are now in the uppercase.
完成的
That's unfortunate, I'll probably still try it via the legal way, but I don't think I will replace my entire display assembly for a broken T-CON board(it even works sometimes, but I have no idea when and why).
Still thank you for your help Dan
完成的
@simontt - Yes, Apple is making it hard! Don't forget to accept the answer - Thanks!
完成的
添加一条评论
添加你的答案
Simon Nattrodt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 122
