跳转到主内容
加入维修社区 - 创建账户
LG Stylo 5 is an Android smartphone that was announced in June 2019.
My phone won't charge why
How do i know if my phone is charged but just has a black screen problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Use a USB multimeter like https://smile.amazon.com/dp/B07JYVPLLJ/r.... If you need something quicker, you can take the insulation off a USB cable, cut the red wire, switch your meter to amps, and hold the probes on the two sides of the red wire. If you see 0.5 amps or higher on the meter, the phone is charging.
完成的
添加一条评论
1个答案
Get a USB C to HDMI cable and plug in in. If it does not show up, you probably have a broken battery or motherboard. If it does you probably have a broken display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shawntay Potter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 534
