iPhone XR doesn't turn on or show any current?
Hello, I have an iPhone XR logic board which I replaced the charging IC on, (it didn’t boot before replacement) and it still won’t boot. When I press the power button there is no change in the current and it stays at zero. The logic board is not getting hot. Any ideas or solutions? Thank you for your help!
We will need a lot more info for us to help you.
What charging IC did you replace? Any amp draw when you prompt to boot with usb cable?
由 Chris Stables 完成的
I replaced charging Tigris IC (U3300). I replaced this chip because it was getting really hot, and after the replacement it was no longer getting hot.
I installed the motherboard into a housing and connected a DC power supply to it, and it didn’t draw any amps. I pressed the power button however it still stayed at 0 amps.
由 Colby Morris 完成的
@Colby Morris It could be a faulty coil. They often fail on the XR. I would replace L3301, 2, 3, 4. I usually replace these when replacing Tigris.
由 Chris Stables 完成的
