跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
914 个问题 查看全部
Distortion on earpiece after replacing screen
I’ve recently replaced a broken screen on my iPhone SE (2016), the replacement is not an official iPhone screen but from an observational point of view and according to the website, it is of high quality.
However, ever since I installed it, the earpiece of my phone sounds distorted, not only to myself but also to whoever I am on the phone to, which makes me think that the distortion is affecting my phones noice cancellation.
I suspect that when I re-attached the earpiece I may have fixed the screws too tightly, and in doing so, preventing the small springs that are attached to the earpiece from absorbing enough vibration to prevent the distortion.
Any thoughts over what can cause this problem would be very much appreciated, thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
As you said, this is likely due to the installation of the earpiece speaker and front sensor flex assembly. Should be easy enough to open up the device and remove the shield over the speaker. Make sure all the sensors are aligned and everything fits well(eg. no force required for it to be flush with screen), and then put the shield back on, not too tightly.
Turn it back on and give it another test and see if anything has changed. Typically if the speaker is making even some noise, that means it isn’t broken and may just need to be cleaned or aligned properly. Also make sure the speaker grille is clear and clean, although that shouldn’t be an issue on a new screen.
这个答案有帮助吗?
得分 2
评论:
Thank you so much for a very detailed answer.
完成的
添加一条评论
添加你的答案
Gareth S. 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 9
