跳转到主内容
Why is my MacBook Air 2014 not powering up?
I decided to restore my MacBook Air 2014 few hours ago, after wiping the HDD through the Disk Utility, I tried to re-install the OS X and it started the update for a while and all of a sudden the screen just went black and it didn’t come back up again. I tried to press down the power button for it to power on but nothing seems to be working as the system refuses to power up at all since. Please has anyone ever encountered this issue before?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi press the pwr button and hold down the Option button
这个答案有帮助吗?
得分 0
1条评论:
Tried that just now and it still didn’t power up
完成的
添加一条评论
Lets give this a try, follow this guide to disconnect the battery stopping at Step 3 2014年初 MacBook Air 13" 电池更换
Now with nothing plugged in, press the power button for a good 15 sec to fully discharge the system. Now plug in the MagSafe charger (don’t connect the battery) your system should spontaneously restart, did it? The MagSafe charger LED should be Amber if not you’ll need to clean and inspect the MagSafe charger contacts.
Make sue your cable doesn’t look like these!
If they do you need a new charger!
Do the pins look OK
Make sure the plastic area is also clean like the bottom connector.
Here’s the proper charger for you system Apple 45W MagSafe 2 Power Adapter for MacBook Air Don’t go cheap! The knockoff chargers are no good!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Donald 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 40
