What is for enter pasword
I could not find any bios battery. still want a password to start computer. when powered on shows ASUS then enter password. what is that password?
From what you are describing here it sounds like the laptop has a BIOS password on it. The method to removing these passwords varies depending on the make and model of the laptop, sometimes you can pull all batteries and power sources (including CMOS) for about 15 minutes and that does it. Other times the password is stored in non-volatile storage in which case the chip containing the password will need to be changed, typically requiring soldering. Do you know what the model number is? It should be on a label on the bottom of the laptop, sometimes they are hidden underneath batteries.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 21
1条评论
What is the exact model of your laptop so we can tell you where the BOIS/CMOS coin battery is?
由 mike 完成的
