跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
iPhone XS automatically shuts down once plugged to charger
Recently I replaced my iPhone Xs battery, my phone was working fine in starting for at least one week, then problem comes, here is weird problem, when i plugged to charger it start charging like normal, once screen goes dim & phone goes to auto lock, within one minute it auto shutdown & won’t charge, even if i press power button, it won’t power on, unplugged and plugged again, no effect, normally with plugged to charger iphone power turn on , but this won’t happen in my case, now if i unplugged to charger for 5 seconds, phone auto turn on & i even no need to press power button, weird thing is if i plugged to charger and let phone screen keep on, it charging normal like normal, phone battery work fine & it never goes auto off phone while using phone, not sure where to start find problem, as i already destroy my old original battery while trying to change original protection board of battery, i broke original battery flex cable, so i don’t have any other battery which i can try to check if that is battery faulty or phone motherboard it self or it might be charging board, phone can connect to pc with no issue and as i said it charging battery with no problem if phone screen is on so what i am doing is make auto lock never & make brightness to zero, so let it charge my phone, once it 100% i make it back to auto lock & increases brightness to normal, but this is not the solution, so i am wondering if anybody know what is all that, have anyone else faced similar problem?
any help shall be highly appreciated,
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
32条评论
Does the phone get unnaturally hot when charging?
完成的
No its not, either i let screen keep on while charging or phone auto shut, in both cases it not get hot at all
完成的
Have you tried making a back up of all the data on the device when it will operate fine, and then erasing everything from the device? This will help you make sure it isn't software related issue before you start replacing more components in the device.
完成的
@smashedliam
I had not tried yet, let me try this first
完成的
Bro I have this exact problem, it’s so weird I am starting to think it’s a firmware issue??
完成的
显示更多的27条评论
添加一条评论
31个答案
已选择的解决方案
Ok i answered my own question, Charging port flex fixed the problem, after replacing with another original one phone work normal again, not sure how it behave like this but it works in my case, hope this will help to other who facing similar problem with iPhone XS.
这个答案有帮助吗?
得分 4
23条评论:
Hi ! Thank god i found this. I had similar problem ! I also have problem when plug in earphone sometimes. Sometimes it happens, sometime dont. So the solution is to change a new charging port right?
完成的
Have u fix the problem?
完成的
@Azeril Razak i have the exact problem. iphone Xs Max user. its really the charging flex i dont know yet what the cause is
完成的
Change your charging flex cable and you should be fine
完成的
Hello I also have this problem but somehow when I tried to change the charging port flex the problem is still the same. It works for a while but after a full charge my phone became so hot the the problem keep happening.
完成的
显示更多的18条评论
添加一条评论
This is my issue with my XS right now. My workaround is to play Spotify on loop with a playlist long enough for a full charge, plug the charger, then turn off the screen.
I wonder, would a wireless charger be an effective workaround?
这个答案有帮助吗?
得分 4
6条评论:
Update: About a week after I had posted this, I noticed that I could go back to charging the old way - iPhone on standby and no music running. Really strange how it “self-healed” after a while. Apart from the workaround of having spotify play in the background while charging, I don’t recall doing anything else out of the ordinary. So far, so good…
完成的
@migoymigs Have you updated your iPhone?
完成的
This method use to work until today. It kept shutting down on me today.
完成的
Why is this only happening to iPhone xs users?
完成的
I also have same issue. Did you find any good solution because earphones also not working on it@migoymigs
完成的
显示更多的1条评论
添加一条评论
I had same problem too.. whenever i charge, i have to open any video so that my phone can charge until full.. it works.. my phone did not turn off while charging but i have to make sure the phone are used while charging. If not, it will turn off and not charged. Do you do the same solution as i did? Im worry it will be more effects to my phone.
这个答案有帮助吗?
得分 3
1条评论:
Hi, im facing the same problem as well. I had to play my spotify until fully charged. Do u still face the problem
完成的
添加一条评论
I have the same issue too but a apple care provider told me it’s the battery that needs replacing
这个答案有帮助吗?
得分 2
添加一条评论
i have turned ON Tap to awake and Back Tap : Double tap Lock feature and now my iphone is not getting switch off while charging.
Its been a week and my iphone is perfectly working now.
Guys! you all should try this Trick and let me know, is it workable to you all or Not.
这个答案有帮助吗?
得分 2
3条评论:
gonna try this hope it will work on me
完成的
did not work on me
完成的
Try changing battery this did solve the problem
完成的
添加一条评论
I also have the same issues…. But you can try this
Play a song and put it on repeat then reduce your phone volume to 0…your phone won’t turn of even if it locks…. It would still be on
这个答案有帮助吗?
得分 1
1条评论:
It will make the screen go blind I did the same thing I changed screen for three times, I think it's the charging ic I changed the flex it still acting up I'm using xs Max I'd I had known wouldn't have brought xs max
完成的
添加一条评论
Same issue I faced after the updation of new OS version. I think it would be some bug issue on software update. apple will fix it soon I hope🤞
Then I find another way to charge my XS & that mission was success..💪.sorry to u all actually…. I will not share because it’s a secret 😂
**Guys, Please try this—— connect lighting cable to laptop USB port & try charging. ur phone will not shutdown🙏
这个答案有帮助吗?
得分 1
添加一条评论
I have this issue sometimes back. It went away after a month.
Last week, it came back again.
However, after I sync it and backup with iTunes, the issue gone.
这个答案有帮助吗?
得分 1
4条评论:
follow up did restoring resolve it, fully?
完成的
@char-lyn medical did you fix yours problem?
完成的
Recently, my iPhone XS started to getting worst.
I reported in 2022 that it would restart itself if it entered standby mode during charging.
Yesterday, it started to restart itself once the phone entered standby mode.
The process drain out the battery quickly.
Today, I updated to iOS 16.3. This issue seems go away. I have tested 4-5 times.
Hopefully it really solved the issue.
完成的
Just an update to my Feb 5 post. My iPhone XS started to restarting itself after 2-3 power off/on.
Then, I reset the phone to factory default. It stayed ok at factory default. After I sync my backup back to the phone, the issue appeared again.
So, I suspect there is some conflict with some apps.
Slowly, I upgraded the apps 1-3 apps at a time. After the update I put the phone into standby mode to check whether it will reset.
This effort and issue last for the next 2-3 days.
Then on Sunday, I realised the issue go away.
The last 4 apps that upgraded in last 2 days are Amazon Shopping, WhatsApp, Skype and PRISM+ Connect.
Hope this info help you solve similar issue like me.
完成的
添加一条评论
I have the same problem. I'm using iPhone Xs. It happened to me yesterday and now I have to use the phone while charging. I think this is a firmware issue. I think this can be fixed with DFU Restore.
这个答案有帮助吗?
得分 0
4条评论:
Did you get yours fix through DFU Restore?
完成的
I did a DFU restore. I think my phone just crashed, During the installing process, the phone is supposed to reboot, but it couldn’t because of course the lightening cable is plugged in. Now it’s showing me a laptop sign and an Apple site to visit.
I think I’m going to change my charging port and see if it works, if it doesn’t, I’ll just change the batter and try as well.
完成的
Update. After it crashed, i changed the charging port flex and restored it. Now everything is working perfectly.
完成的
So changing the charging port flex is the fix?? Currently having this problem now. At first my power bank could not charge my phone later my fast charger anytime I plug it and the phone goes dark it goes off
完成的
添加一条评论
Okay I had this workaround since the music player trick also stopped working.
I'm not sure what's really at fault but mine went back to normal when I did this, after hours of being frustrated because I can no longer use my lightning earphones.
1. iPhone will turn off once lightning connector is plugged.
  1. Phone will turn on once lightning connector is unplugged. Apple logo will come out.
  2. Count to SEVEN and plug the lightning connector back, waiting until the iPhone finishes its boot-up process.
  3. Once your lock screen flashes, you can now use your lightning connectors normally.
    Repeat if it fails.
    I'm really not sure why it works, but apparently, the issue returns if I swiftly remove the lightning connector. I repeated the process above and again, iPhone goes back to working normally.
    I suspect this is really some bug.
这个答案有帮助吗?
得分 0
4条评论:
PS:
I can confirm that this could be a combination of a bug and a charging port flex issue. For some reason, I feel like when the port was shorted or slightly bent, and whatever electrical flow activated during connection of the lightning connector to the port causes the system to restart or shut down. A slow insertion of the lightning connector at an angle to the port during boot up seems to solve the problem every time.
BUT in my case after updating to IOS 16, this only happens when connecting earphones through the lightning port - USB lightning connection seems to have been resolved.
完成的
Ooops. Nope. Problem still persists, but with variations of severity. Hahahaha.
This is a bug.
完成的
Definitely a bug. It's now resolved.
完成的
how did you resolve it? did you factory reset?
完成的
添加一条评论
After updating to iOS 16, my problem has been resolved. I hope that this will be useful to you!
这个答案有帮助吗?
得分 0
2条评论:
Unfortunately, it came back again.
完成的
do you still have the problem?
完成的
添加一条评论
I have same problem, i was take to Apple service (unofficial) and they said the problem from the machine flexible or something that cost $66. After read the same problem from the internet i think to cancel the reparation
这个答案有帮助吗?
得分 0
1条评论:
did you fix your problem?
完成的
添加一条评论
now i found something to know what is the problem of your iphone download 3uTools on laptop, i have a problem called panic cpu x caller and to really get it https://www.youtube.com/watch?v=QaJLYbtu... watch this guy to explain it to you hope this help
这个答案有帮助吗?
得分 0
1条评论:
and i found a second way is to turn off my wifi i can finally charge while my phone is off i think
完成的
添加一条评论
Ok i had same same issue when i used fake charger some days tried changing flex cable (ribbon) but it did not fix it turns out because my battery health was on service it just need to be replaced this did the trick♥️
这个答案有帮助吗?
得分 0
添加一条评论
I am also suffering the same issue. Iphone xs getting switch off after connecting the lighting cable. My battery health shows 81% & I have done the factory reset as well but problem still exists.
After removing the lighting cable, apple logo appears and again getting off after screen goes to off.
Note that - apart from playing a song and connecting to the charger, Removing the screen timer do we have anything to recover this issue
Is this happens due to software bug?
Did anyone resolve this issue ?
这个答案有帮助吗?
得分 0
添加一条评论
How to solve this. do i need to repair or change my charger flex!!!
这个答案有帮助吗?
得分 0
添加一条评论
I think there are few possible causes:
  1. iPhone has detected connectivity issue with cable. Verify with an original hood iPhone cable to confirm.
  2. iPhone firmware issue. Verify by setting ‘Auto-Lock’ to ‘Never’
  3. Battery issue.
这个答案有帮助吗?
得分 0
添加一条评论
I'm using iPhone Xs. I have the same problem. It happened to me yesterday and now I have to use the phone while charging. But last night my battery was like 20% and I forgot to charge it and when I woke up it showed the sign of my phone needed to charge right now. But the problem is when I put my charger on, my xs will instantly shut down... so I cant charge my phone right now.. at all.
这个答案有帮助吗?
得分 0
2条评论:
Try charging with PC to check whether it can stay on.
If it can stay on, switch off the auto-lock feature.
完成的
Set ‘Auto-Lock’ to ‘Never’ then trun down brightness of your phone. Then plug in. This way you can charge your phone.
This auto turn off issue comes time to time for me. I don’t know permanent fix for this. Probably this is a firmware issue.
完成的
添加一条评论
I took to to a care shop and they changed the charging flex. Working quite well now although slow with power bank. Need to change my battery for that
这个答案有帮助吗?
得分 0
1条评论:
How much is your device's battery health?
完成的
添加一条评论
my issues started around the time I started using power bank to change my phone not am not able to charge it
what happens is when you plug the cable in or when you put the phone on a charging pad the phone shuts off
tries to turn its self on but the screen flashes for a second during the logo appearance and never comes back on
just keeps repeating the same thing
  1. logo appears
  2. screen flash on left and right sides of the screen
  3. repeat
I tried everything that you can find online.
The playing songs etc while charging didn't work.
Resetting no go.
Apps updated nothing helped.
If I were to guess it must be a battery issues that prevents it to bootup.
I will let you know if I find a fix.
这个答案有帮助吗?
得分 0
4条评论:
Any updates brother?
完成的
I have the exact same problem
完成的
update it to ios 17.1
完成的
Does it work?
完成的
添加一条评论
I have this exact problem right now and here's my attempt to charge the phone so far (unfortunately it doesn't resolve the problem) :/
Anyway, here's the methods:
  1. disable the auto-lock feature so your phone will not go into lock-screen mode, then charge your phone (if you're using the official iPhone charger with 1A output)
  2. no need to disable the auto-lock feature so that your phone stay "on" at all times (i.e. charge as per normal), BUT you need to use a higher output charger (eg iPad charger or Power Bank with at least 2.1A output or above)
Hope they help!
这个答案有帮助吗?
得分 0
添加一条评论
I am also facing the same issue on my iphone xs after updating to ios 16.5. Whenever i plugin my iPhone charger or earphones charger to the port, it gets switched off and as soon as i remove the charger from port, the apple logo appears(Phone Restart happens). Currently i am playing some music behind and charging my mobile. Batter health is degraded <80%.
Any suggestions or fix are appreciated.
这个答案有帮助吗?
得分 0
2条评论:
Ong, currently my iPhone XS is experiencing this as well after updating to iOS 17. I have to turn on the screen or use it to charge the battery. And when I use my iPhone earphones, it suddenly turns off.
完成的
update to ios 17.1
完成的
添加一条评论
You guys really tried about “BACK TAP ON”
It’s working for me
这个答案有帮助吗?
得分 0
添加一条评论
I fixed the issue it is that you have to change your battery and it will solve no worries worked for me too
这个答案有帮助吗?
得分 0
1条评论:
No did that doesn't work
完成的
添加一条评论
My issues was that I had water damage on the charging board that caused it to short circuit
这个答案有帮助吗?
得分 0
1条评论:
So you changed the charging port?
完成的
添加一条评论
Still having the same issue for my xs max. My solution is play music on mute then charge my phone. It works all the time.
这个答案有帮助吗?
得分 0
2条评论:
It will blind the screen
完成的
It will not. Since you can turn it off
完成的
添加一条评论
i have been facing the same issue on my iphone xs just today and i couldnt wait to resolve it, so hopefully there was an ios version available (17.1). i updated the ios and its kind of working fine now.. lets see if the problem comes back again haha
这个答案有帮助吗?
得分 0
添加一条评论
Solution:
Restore iPhone. Means a complete wipeout, different from the usual reset or erase. Doing that and restoring a Finder Mac iTunes backup will bring back issue still.
Thereafter, restore from iCloud backup. The only way forward. And do not let your battery drop below 20% anymore.
After I did the above, the issue went away. Just hours ago, when I inevitably had to drop the battery below 20% because I did not have my charger, the issue has come back. Hence as follows.
这个答案有帮助吗?
得分 0
添加一条评论
My XS max used to switch off when the charging pin was connected and switch on again after the pin was disconnected. If the phone got heated up, the charging % was very less.. I had switched to charging by a wireless charger for the last 6 months.
after the recent update to iOS 17.1, wireless charging also failed.. I took the phone to a local unofficial Apple service who diagnosed the problem was due to charging port. He replaced the port and the phone is now charging well, like before 😀 whew!
这个答案有帮助吗?
得分 0
1条评论:
Go to Settings - Battery - Battery Heath & Charging - Turn off everything.
完成的
添加一条评论
what i did was opening google maps and start a journey to any destination turn off the mobile data, turn off the screen and keep for charging, I did it almost 10-12 times and the problem go solved by itself, But remember to charge your phone before it goes below 10/20 percent as the issue may come up again
这个答案有帮助吗?
得分 0
1条评论:
Solved 😍😍😍😍
Issues with X app only please uninstall
I have have tried many ways but not solved
It solved after uninstalling X app please share this message
完成的
添加一条评论
My iphone XS max has been fixed. Using 17.3
Turn of battery optimization .
Solved prolbems.
这个答案有帮助吗?
得分 0
1条评论:
I hope it works!
完成的
添加一条评论
添加你的答案
The101 将永远感激不已
浏览统计数据:
过去 24 小时: 56
过去 7 天: 531
过去 30 天: 2,489
总计 49,417
