跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
149 个问题 查看全部
Can I add a gpu to help zoom quality of my video? Internal or external
In zoom, my own video is very poor, looking lower res than a 720p camera should be giving me. Same with or without green screen, with or without a background image, and with or without iGlasses. Cpu load is very high with zoom session. Perhaps an internal or external GPU would help. I'd appreciate any suggestions.
I have a 2018 MacBook air.
Update (07/21/2021)
Did some more digging… I found that zoom does not provide HD for "free" customers due to bandwidth concerns, COVID impacts on the rapid growth of their customer base, etc.  I upgraded to Pro for the month, and enabled HD in my account settings.  I've not done a serious test yet but it looks like that improved things.  The following two pages were my primary references. Note that the Group HD is not shown if you’re a “free”user. Upgrade to Pro and that option is shown, and enabling it improves quality. All set for now. Thanks…Alan
https://support.zoom.us/hc/en-us/article...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
这个答案有帮助吗?
得分 1
添加一条评论
I'm surprised your direct view of your own video image from the FaceTime camera is so bad. See if the Photo Booth app your system has in the application folder is any better.
If not then your system is likely in CPU safe mode which is when your SMC logic detects a problem! Basically it lowers the CPU's clocking and ramps up the fan.
Lets see if you get an error running the onboard diagnostics. Restart your system and press the D key did you get any errors?
Reference: Mac startup key combinations
As far as adding a GPU you shouldn’t need it, you would need an external GPU and I promise you no one is doing that for Zoom calls. The background image really doesn’t effect things (green screen).
If your system doesn’t come back with an error I would look at reducing you drive of stuff as you maybe running out of storage space, in this case preventing your apps access to virtual RAM.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alan Carwile 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 368
