跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Why doesn't my iPhone 6 refurbished replacement screen sit flush?
Hey guys,
I recently replaced my iPhone 6 screen with a refurbished display from Easyphix, and after switching over the components from the old screen to the new one and installing the new screen, I noticed that while the top of the screen fit properly, the rest of the screen was slightly lifted up from the phone chassis [See image here or below - https://imgur.com/a/zRpb8ut ]. (The gap on the right is ~1mm wide and properly depresses when I press down on it so I don’t think its due to a blockage of some kind. Perhaps faulty screen clips?)
I should also note that with the old screen, I cant tell whether that has the same issue since it has so many cracks make parts of it not sit flush anyway.
I've tried fixing the slight bend in the phone but that didn't help. I've also made sure all screws are screwed in well.
The only solution I've found to a similar problem was to replace the battery due to potential swelling, however looking at the battery, it appears completely flat so don't think that's the problem.
Any ideas, and suggestions will be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If the screen sits properly when pressed down, it might just need some adhesive near the bottom of the frame. The bottom of the screen doesn’t have many (if any) clips, and adhesive should hold it down. Hope this helps!
这个答案有帮助吗?
得分 1
3条评论:
Ooh that's a really good suggestion. Do you thinkg using an adhesive for the iPhone 6s would be the right size and be strong enough to prevent this spring back? (because the iPhone 6 doesn't have its own screen adhesive)? or just any double sided tape?
完成的
Most double-sided adhesive tape should work, as long as it is pretty strong. I’m not 100% sure if iPhone 6s adhesive will fit the frame, but even if it did I don’t think it would be strong enough to hold it.
完成的
Ok sweet! I'll try that then, thanks.
完成的
添加一条评论
添加你的答案
Gordon alberts 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 301
