跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
577 个问题 查看全部
Black screen while start, external monitor does not work.
Hay
I have a MacBook (13-inch, aluminum, late 2008).
If i turn it on, i hear the start sound but the screen stays black.
An external monitor also does not work.
I tried to reset the NVRAM/PRAM and its still not working
Any Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Do you see a slight glow of the display in a darkened room? If you do your logic board needs repairs or replacement.
这个答案有帮助吗?
得分 0
3条评论:
I will check this
完成的
The display stays black, there is no slight glow.
完成的
Time to visit an independent mac repair shop!
完成的
添加一条评论
I had this problem a while ago with a clients computer. After trying the usual troubleshooting by resetting PRAM etc. I took off the back to discover that there was massive corrosion on the powerboard and that the moisture indicator had turned red. After cleaning the electronics with Isopropanol, which will dry out moisture and also remove most corrosion, and removing the battery the computer started but ran very slowly. After also replacing the battery with a new one the system returned to normal
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Philipp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 65
