跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Power not detected after battery replacement
My old iPhone 5s wouldn’t take a charge (after being left in the drawer for a long time). I replaced it with the ifixit battery and kit. After the replacement, the phone turned on with about 50% battery, and everything worked fine. However, when I plugged in the lightning cable, the phone did not detect the connection. The cable is fine: it works fine with another iPhone. Did I loosen some connections somewhere? Where should I look?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Its probably in the connections, look where you connected it.
完成的
添加一条评论
1个答案
最有帮助的答案
As the other user commented, try checking the connections between the logic board and the charging port to see if anything is loose. Otherwise ensure that the charging port itself doesn’t have a build up of dust in the port, but if it does you can simply clean that out with some tweezers and a steady hand. I usually find most cases of no charging can be resolved by cleaning out about a centimetres worth of dust.
If the port is all clean, the connections are all clean and secure, the charging port may be faulty and need to be replaced, but it may be worth taking the device into a reputable repair shop for a diagnosis.
这个答案有帮助吗?
得分 2
1条评论:
I tightened all the screws, and couldn't see anything loose inside. I did have a lot of lint and I cleaned it up. Still no power. One thing that is curious is that whenever I connect the lightning cable to the (off) phone, it wakes it up. That means something is connected, but it just won't charge.
完成的
添加一条评论
添加你的答案
Wilson Law 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 40
