跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
Is this part of the wireless charging module important?
Please refer to the following image. What’s the purpose of the cable that extends from the main ribbon? Is it just there to adjust firmly the wireless charging ribbon? Or does electricity flow through it?
While I was removing the battery of my iPhone XR I accidentally stretched that part, though it did not break.
However I’m not sure if I should be concerned as it doesn’t seem to connect to any phone component.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Looks like the Hall effect sensor for the case cover or the compass.
If the phone OS complains the sensor missing, replace it, otherwise the phone may keep trying to query it and heat up.
这个答案有帮助吗?
得分 2
2条评论:
@tomchai I just tested my phone and when I open the Compass, its stuck pointing north. Does that mean the compass is physically damaged?
完成的
@tom16 seems only logical.
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 42
