跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Touch ID failed after a screen replacement but the home button works.
I don’t know this has been answered or not but today I repaired my grandmom’s iPhone 6. After replacing the screen, the touch ID stopped working but the home button function still works. Does this have to do with the back shield connector from the touch ID sensor to the Motherboard or the Touch ID is gone forever?
Upon further inspection, the touch ID sensor seems fine and I’m very careful at pulling it out from the old screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
In settings is the fingerprint greyed out or will it let you try to set it up?
完成的
it would let me enable but it says failed afterwards
完成的
添加一条评论
2个答案
已选择的解决方案
I would try replacing the home button flex cable as it might be damaged. You can purchase the flex and back plate for around $5.00 or just the flex for less.
这个答案有帮助吗?
得分 1
添加一条评论
So if you have swapped the home button and it still won’t work then Apple has to reprogram it for Touch ID to work again.
这个答案有帮助吗?
得分 0
1条评论:
I'm still using the original home button and touch ID was enabled before the screen replacement.
完成的
添加一条评论
添加你的答案
Nicholas Hoi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 40
