跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。可選GSM/CDMA,eSIM/nano-SIM,64GB/256GB/512GB,銀色/金色/太空灰色。讀法是“iPhone Ten S"。
Do I need to program aftermarket proximity sensor?
My iPhone XS was in the apple boot loop. I isolated the issue to the proximity sensor/speaker component. I quit on trying to find an inexpensive repair in order to preserve face id so I will replace the component. Since the ALS has to do with truetone. If i replace it will I have to program truetone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes you’ll need to program the new assembly to keep TrueTone. This one should do the trick https://www.jcprogrammer.com/jc-v1-iphon...
这个答案有帮助吗?
得分 1
添加一条评论
Replacing the front flex assembly will not preserve true tone even if he re-programs the display, you will need a jc receiver flex to transfer over the data from the phone or the old flex if you still have it, This way you can preserve face id and even true tone or you can transfer over the components by using hot air to a known good working flex cable assembly. :D Hope this helps!
这个答案有帮助吗?
得分 0
2条评论:
I have the old flex, but it was causing the phone to boot loop (water damaged). So I doubt it will work. The JC Receiver board actually restores face id with an aftermarket flex?
完成的
Yes, it does. But I guess you need a jc receiver flex itself for it to restore and work again!
完成的
添加一条评论
添加你的答案
Leonardo Mendez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 426
