跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
475 个问题 查看全部
Do I need a replacement screen?
I recently dropped my phone, despite being in a case a large black line has appeared on the screen. There is no external screen damage as such, however the charging port is also slightly damaged. I presume this will require an entire screen replacement to be fixed as it is not a software issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
yes,
from the picture it does look like your screen will need to be replaced. sorry about the bad news.
usually if its software you can wipe the phone first and start fresh and that would go away. im 99% sure thats a hardware issue.
这个答案有帮助吗?
得分 1
添加一条评论
You have to replace the new LCD.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
D Sheerman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 35
