跳转到主内容
The Fitbit Alta HR is a fitness tracker wristband released in March 2017. The Alta HR is similar to the Alta, which was released in February 2016.
Is it possible to replace the charging port?
The charging contacts are getting very damaged and causing inaccurate charging. Is there a way to buy this piece and replace it, how do I replace it? Thank you. Fitbit Alta HR
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
if you can access the port and the board it should be possible to replace the charging port.
if you dont have the proper tools, IE hot air station, solder, flux, new port it could be more costly to do it yourself as opposed to sending it to a repair shop.
hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicole 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 369
