跳转到主内容
加入维修社区 - 创建账户
7.9 英寸显示屏 / 型号 A1432 / 提供黑色或白色版本 / 2012 年 10 月 23 日发布 / 16、32 或 64 GB 容量
Removed R1204 resistor, Impact?
Hi! I with all of my stupidity i read online articles mentioning about the possibility of hardware icloud bypass for a1432 ipad mini 1 by removing resistor r1204. Without knowing how it works i follow the instruction blindly and ofc it will not works
But the ipad mini still turning on without indication of impact other than video not working (microphone? Camera working fine). Do u guys know what i removed and how it may impact my device? ( i think i damaged the component beside and above it, circled blue in the picture)
thank you, any answer will be really appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Last time i checked i thought this icloud removal method will only work for the ipad mini 4G not wifi models but i could be mistaken. However, if you damaged R0941 which right next to R1204 then it can give you issues because it’s linked to rear camera and on the other side C0961 and 62 are linked with the front camera , and the one above R0720 looks like its some kind of CODEC for speaker/amp. I know im not giving you a solution here but perhaps with this information and maybe some little research it might lead you on the right path. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Walking Mushroom 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 33
总计 4,329
