跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Stuck in Bootcamp: cannot reset OS at startup
hey guys - i am having issue with my internal keyboard that is being overwritten by my external keyboard so i cannot, at startup, press the option key to go back to my MAC OS….therefore i am stuck with WINDOWS.
Does anyone know, at WINDOWS via terminal or whatnot, make the machine select the MAC OS as default? im so desparate that it d be ok with deleting windows altogether…assuming i can go back to my MAC OS. again…keyboard isnt working properly…even with an external one i cannot press some keys (apparently) at startup…
please help! thanks a bunch
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
While I can’t help you over come the stuck keyboard input. I might be able to offer a way to get to your apps and data from a second Mac connected in target Disk Mode
See if you can get that far. As it sounds like you’ll need to get a new system as the cost t fix your system maybe too expensive.
这个答案有帮助吗?
得分 1
2条评论:
bummer! would you say that to try and look for the fault in the logic board is a bit farfetched at this point?
is there a way that i can reset the mac entirely (delete everything) without pressing the R key at startup (remember i have an issue with the keyboard + stuck at windows booting by default) :)
many many thanks!
完成的
@amendes - Sorry I can't see ant way without keyboard access. I think it's time to find someone with deeper pico soldering skills.
完成的
添加一条评论
添加你的答案
Antonio Mendes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 74
