跳转到主内容
任天堂3DS系列系统的实体游戏卡带,最初于 2011 年发布。
Game Card Will not Work in any System
So I have a copy of Tomodachi Life that whenever I start it says “ An error has occurred. Hold down the POWER Button to turn off the power, then turn it on and try again. For help, visit support.Nintendo.com.” Here is a picture of the error -
I don’t think this is the system because all of my other games work fine and it does this in multiple systems. I opened the cartridge to see if one of the pins were disconnected, but I didn’t see anything. Here is the board -
Does anyone know why this is happening and what I could do about it? Thank you.
EDIT: Here is an image of it running on a 2DS as well.
(yeah I know the circle pad needs fixed)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
Have you tried cleaning the contact tabs? I have fixed many carts by doing the following. Use a pencil erasure to carefully rub the contacts, length ways NOT cross ways. Keep at it until they look cleaner. Then use 90+% IPA or contact cleaner to finish.
I have never come across a cart for any system ever that was just plain dead. I’m sure it can happen though. I have however encountered many that were dirty in one way or another (just plain filth, and or corrosion), cleaning has fixed every single one so far.
这个答案有帮助吗?
得分 2
1条评论:
Just tried to fix it with the eraser, I had already used alcohol but did it again for safe measure. No different result, still immediately goes to the screen.
完成的
添加一条评论
Check every leg on each side of the chip for movement. Nintendo soldering is known to crack over time. Use a pair of fine tweezers or a pin to put slight sideway pressure on each leg. If one moves it needs re soldered. Check every leg.
Also check both capacitors beside the main chip in case one has shorted to ground.
这个答案有帮助吗?
得分 1
添加一条评论
Looking at the cartridge internals picture, it looks like the connecter pins are very worn out. If you have any kind of material that can cover and connect the pins [liquid copper, copper tape] try to use that, then try the cart. out in a 3DS or 2DS.
The following image attached helps highlight how worn the pins are. Over time, due to inserting and ejecting these carts, the pins do wear out over time.
Hope this helps!
BTW: If the pins are badly worn out, the connections may not work right.
这个答案有帮助吗?
得分 0
2条评论:
I have the same problem with one of my cartridges, so you'd recommend copper tape?
完成的
For badly worn pins, copper tape should help
完成的
添加一条评论
I have the same issue with one of my cartridges, how did you manage to get it open and are you able to close it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mr. L 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 153
总计 6,643
