跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1526 个问题 查看全部
Why does my iPhone occasionally restart on its own?
I decied to repair my screen by myself and I managed to pull it off. However, upon placing the screen back on, the phone occasionally restarts, as if I completely powered it off, then held the power button. The phone would also appear to not be able to be charged. Does anyone have any idea what is going on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
First, if the iPhone restarts then it capture log data. Check that log data and see.Sometime loose contact of battery to battery connector might also show that issues.
这个答案有帮助吗?
得分 1
3条评论:
How do I read the analytics?
完成的
Sorry, I'm not the brightest
完成的
While the iPhone restarts it captures the analytic log.That can be found on the settings/privacy/analytics & improvements/Analytic data and search the Panic log. If you have any problem follow those instructions will help you to find it in easy ways.
完成的
添加一条评论
Try cleaning all of the connectors between the screen/battery/cameras/logic board with some alcohol and make sure they’re all seated correctly in the sockets. If the phone is still boot looping from here you can try disconnecting things from the board to see if any modular components are faulty. If you unplug everything from the logic board except for the battery and display, and the device is still boot looping, it may be worth trying to reset the device in DFU mode before replacing the battery or screen. If you’ve tried to wipe the board and aren’t able to, you should at that point take the device into a reputable repair shop to get a diagnostic of the problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ethan Ethan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 32
