跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
RB doesn't work at all
Hi all!
I bought a used controller that looked unused cheap and I found out later that the right bumper doesn't work.
I'm new to controllers and this is what I've done:
  1. Updated firmware on Xbox accessories app
  2. No input from RB in testing software(Tried pressing hard and ALOT
  3. Opened up to see whether the bumper arm was broken but it's still pressing onto the switch
Would appreciate any advice as I'm planning to solder on a new switch from AliExpress.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’ve come across this with other devices that utilize essentially the same sort of module. They are a pain to take apart and re-assemble. However in each case what I found was barely dirty/dusty/oxidized/corroded internals.
My new nintendo 3ds power button was randomly turning on and or off. I disassembled it and used canned air to blow around the little button into the button module itself (not the external button). You might need some way to depress the button or shove it a little to the side, so the blast of air can fully enter the module. In another case I had canned air didn’t work but contact cleaner did.
But since you plan the nuclear option, full replace. Wouldn’t hurt to try air or contact cleaner first.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Leonard Wong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 174
