If it does not crank at all I would look at clutch safety switch. If it does not crank. Check to see if you have spark. And check to see if you have fuel pressure. Some times the wire running to fuel pump is near tranny. And can get pinched or cut while removing
any issues before the clutch change or just a routine change?
由 jay 完成的
No issues aside from burnt clutch
由 John Barrett 完成的
does it crank over at all the engine or is there no signs of life?
由 jay 完成的
I know a clutch job can be quite involved depending on the vehicle but did you check to make sure everything was connected?
由 Jesse Hooton 完成的
由 GKJarhead 完成的
