跳转到主内容
苹果的第四代无线键盘 发布于2015年10月 型号A1644
Keycap not properly fixed in its place
Hello
I’m trying to attach UP and Down keycaps, but i can’t get it fixed .. it will pop up.
I have slide the scissor clip in its place.
what could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Its hard to tell as we can’t see the other cap’s clips fully. Did you damage the cap? Its easy to do if you don’t pop it on properly.
There are two L shaped clips which slide in first, then the U shaped clips over the pins. Note they go in from different directions as they are the same part just turned over!
这个答案有帮助吗?
得分 2
2条评论:
Thank you for the reply.
i think the caps are damaged
完成的
@samisultan - Here's one source: Up/Down - Magic Keyboard (Type-N) You'll want to ping them to see when they expect to have more parts and they are out of stock right now.
完成的
添加一条评论
添加你的答案
Sami Sultan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 130
