跳转到主内容
加入维修社区 - 创建账户
这是一款由 Saeco 开发并以 Starbucks 品牌重新推出的易用型家用浓缩咖啡机。这款咖啡机非常适合日常饮用浓缩咖啡的用户,且具有出色的做工和产品寿命。
My Batista is very slow to pump out an espresso. Can I repair the pump
Can I repair the pump in my Starbucks Barista?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello Jellybean100,
To set you up on the positive mindset, “you do a little dance and then you drink a little water”. (RHCP) ?
More seriously, if your coffee is spouting out more slowly than expected, it may be due to the coffee beans used. Try grinding the coffee beans more coarsely.
If the pump has been idle for a while it may become "airlocked" and not work.
  • With the pump running alternatively turn the steam knob on and off.
  • You can use a turkey baster/ear bulb or similar item to force the pump to prime. Fill the bulb with water and insert it into the water hose. With the pump running, squeeze water into the hose until the water flows easily. Then turn off the pump and place the hose into the filled water tank and resume priming.
  • (Starbucks Barista Troubleshooting).
Now, if you've already walked that path unsuccessfully, to replace the pump, head over here: 星巴克咖啡机泵更换
You may also benefit from browsing through the complete teardown here: Starbucks Barista Teardown
Hope that you'll be successful ??
Happy Tuesday ?
Christophe
Starbucks Barista图片
指南
难度:
中等
Starbucks Barista 泵图片
指南
星巴克咖啡机泵更换
难度:
中等
30 - 45 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jellybean100 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 219
